Sgtaylorc
Oct 24, 2020Aspirant
RAX120 Is forcing Auto Firmware Update Every Night
My Nighthawk RAX120 keeps automatically updating to V1.0.2.136 firmware at 01:00, even though I have disabled the “router auto firmware update.” Essentially when the router updates to the newest ve...
mdervin89
Dec 15, 2020Aspirant
I have the same issue. Any resolution? I upgraded to the latest firmware and all wifi devices have problems connect. Revert back to old firware and works great. I have auto update turned off and keeps updating anyway.
Sgtaylorc
Christian: I reinstalled the firmware version, factory reset the router and then ran through the setup assistance again. Unfortunately this did not solve the issue.
mdervin89: After much research there appears to be an issue with DHCP assigning IP addresses. In the advanced settings of the RAX120 you can manually assign address reservations in the LAN Setup tab. It takes time, but after going through this process all 67 of my IoT devices are connecting without issue. Make sure to back up your settings after manually assigning address reservations. Hope this helps!
