thehypnootoad
Apr 25, 2021Luminary
RAX120 Is it ever going to be fixed
Ahh the famous RAX120 the expensive router I want to use but can't due to too many issues (already had rma tried most firmwares even switched provider and changed modems) Unfortunately I would love t...
Apr 26, 2021Guru - Experienced User
This is the netgear community forum. Its rare to find a moderator on here and they don't discuss upcoming firmware changes.
You're running the d7000 as a gateway?
Does the RAX120 have issues when its ran in access point mode and connected ot the d7000?
thehypnootoad
Apr 26, 2021Luminary
Will give it a go I can also use the modem and run 120 in access point only problems is you don't get full functionality in access mode compared to router mode do you?
- plemansApr 26, 2021Guru - Experienced User
You do lose some functions in AP mode but the D7000 should be running those functions.
- thehypnootoadApr 26, 2021LuminaryWould like to use just the rax120 with my modem and get rid of the d7000 hopefully one day. will let you know how I get on.
Are you using the D7000 as a modem?
Or what modem/gateway do you have?
