thehypnootoad
Apr 25, 2021Luminary
RAX120 Is it ever going to be fixed
Ahh the famous RAX120 the expensive router I want to use but can't due to too many issues (already had rma tried most firmwares even switched provider and changed modems) Unfortunately I would love t...
thehypnootoad
Apr 26, 2021Luminary
Will give it a go I can also use the modem and run 120 in access point only problems is you don't get full functionality in access mode compared to router mode do you?
Apr 26, 2021Guru - Experienced User
You do lose some functions in AP mode but the D7000 should be running those functions.
- thehypnootoadApr 26, 2021LuminaryWould like to use just the rax120 with my modem and get rid of the d7000 hopefully one day. will let you know how I get on.
- plemansApr 26, 2021Guru - Experienced User
Are you using the D7000 as a modem?
Or what modem/gateway do you have?
- thehypnootoadApr 26, 2021LuminaryAt the moment im just using d7000 on its own as its vdsl.But would like to use huawei hg612 modem and rax120 but too many issues with that setup.
