rybxwa
Jul 09, 2019Initiate
RAX120 Issues using Windows VPN connection
Hi, Just bought a Nighthawk RAX120 and setup was very easy and quite impressed with boost in speeds and no lag-time on devices. But I ran into one HUGE problem yesterday and spent 90 minutes with NG ...
Christian_R
Jul 10, 2019NETGEAR Employee Retired
Hello rybxwa - I would like to have your case escalated and followed up by support. Would you mind sending me a message with your case number and email address.
Thanks,
Christian
tukstr
Jul 15, 2019Aspirant
I have this same issue connecting Windows 2016 Server Essentials VPN (PPTP).
Thanks!
Joe
- rybxwaJul 16, 2019Initiate
Hi Joe, Try changing the VPN type from PPTP to Automatic. Go to Windows Settings / Network & Internet / VPN / Select your connection and click on Advanced Settings / Then Edit and change the VPN Type to Automatic.
Not sure why, but by changing the setting to Automatic, I was finally able to connect to my work VPN using Windows. Hopefully that works for you.
Good luck and take care!
- jcparhamSep 26, 2019Aspirant
Has there been any resolution to this issue? I am having exaclty the same problem.
Thanks
- Denhom1022Nov 12, 2019TutorAny solution to this issue? Exact same thing....
