rybxwa
Jul 09, 2019Initiate
RAX120 Issues using Windows VPN connection
Hi, Just bought a Nighthawk RAX120 and setup was very easy and quite impressed with boost in speeds and no lag-time on devices. But I ran into one HUGE problem yesterday and spent 90 minutes with NG ...
tukstr
Jul 15, 2019Aspirant
I have this same issue connecting Windows 2016 Server Essentials VPN (PPTP).
Thanks!
Joe
rybxwa
Jul 16, 2019Initiate
Hi Joe, Try changing the VPN type from PPTP to Automatic. Go to Windows Settings / Network & Internet / VPN / Select your connection and click on Advanced Settings / Then Edit and change the VPN Type to Automatic.
Not sure why, but by changing the setting to Automatic, I was finally able to connect to my work VPN using Windows. Hopefully that works for you.
Good luck and take care!
- jcparhamSep 26, 2019Aspirant
Has there been any resolution to this issue? I am having exaclty the same problem.
Thanks
- Denhom1022Nov 12, 2019TutorAny solution to this issue? Exact same thing....
- Christian_RNov 13, 2019NETGEAR Employee Retired
Hello Denhom1022,
Welcome to the Community! Have you gotten a chance to try the suggestion rybxwa recommended?
Christian
