rybxwa
Jul 09, 2019Initiate
RAX120 Issues using Windows VPN connection
Hi, Just bought a Nighthawk RAX120 and setup was very easy and quite impressed with boost in speeds and no lag-time on devices. But I ran into one HUGE problem yesterday and spent 90 minutes with NG ...
MTamasi
Nov 16, 2019Aspirant
Same issue!! Just installed last night and spent 3 hours trying to get to work. Automatic / pptp manually (both ways).
Also my fire tv IPVanishVPN doesn’t work through the nighthawk either.
Denhom1022
Nov 19, 2019Tutor
Just got this issue resolved. It was a bug in the firmware. Go to Netgear support site and download the newest firmware hotfix. After that, toggle your NAT filtering from secured to open, then back to sercure. This should fix the issue.
- MTamasiNov 19, 2019Aspirant
This corrected the issue! Thank you so much!!!! :)
- tukstrNov 19, 2019Aspirant
Thank you, this worked for me too.
- PaulChrisDec 02, 2019Tutor
Fixed the problem for me. with RAX120 and Router Firmware Version V1.0.1.108.
Toggle the NAT Filtering from Secured to Open back to Secured and reboot. This corrected the PPTP VPN connection probem.
