rybxwa
Jul 09, 2019Initiate
RAX120 Issues using Windows VPN connection
Hi, Just bought a Nighthawk RAX120 and setup was very easy and quite impressed with boost in speeds and no lag-time on devices. But I ran into one HUGE problem yesterday and spent 90 minutes with NG ...
Denhom1022
Nov 19, 2019Tutor
Just got this issue resolved. It was a bug in the firmware. Go to Netgear support site and download the newest firmware hotfix. After that, toggle your NAT filtering from secured to open, then back to sercure. This should fix the issue.
MTamasi
Nov 19, 2019Aspirant
This corrected the issue! Thank you so much!!!! :)
