fingaz's avatar
fingaz
RAX120 LAN-side MTU setting
Hey all,
I've switched from an Asus RT-AX82U to the Netgear RAX120 (simply for the Multigig port), and finding a few downfalls (the Asus firmware is honestly MUCH nicer, and power-user friendly...0)
Anyway, I think I already know the answer, but is there a way to set the LAN MTU? I use jumbo frames (MTU9000) across my entire network, but seems the RAX120 doesn't allow for setting this...
It also doesn't allow you to define per-client DNS servers as part of DHCP Static leases, amongst other things.
For a product released 3years ago, it does seem lacking!
Is there any beta firmware, or custom firmware kicking about? Or even firmware source?
Thanks!
1 Reply
  • Oh man, just found this post which echos my sentiments: RAX120 Firmware RIDICULOUS - NETGEAR Communities
    That was a year ago now; so I guess we can't hold out much hope for firmware changes any more? I see the GPL source code is released, but I wonder if this is sufficient to build a custom firmware (maybe openwrt) from...
