Davidtamura
Jun 13, 2020Aspirant
RAX120 loses both wired and wireless connection at midnight
Im usually asleep by midnight but sometimes stay up working on the computer or watching appletv. At exactly midnight, the wifi router stops working. Its not the cable modem, I can still watch regular...
- Jun 17, 2020
It is not in the Nighthawk mobile app, you must use http://routerlogin.net which is the
router login admin page. After you login go to BASIC->Internet. Then you must
select Yes to the question, "Does your Internet connection require a login?". If you are
required to use a login, click Yes. Then scroll down to Connection Mode.
Davidtamura
Jun 17, 2020Aspirant
Please help: Using Nighthawk app version 2.5.1.10 on iphone.
Settings -> Router Settings, Wifi Settings, Guest Wifi Settings, Security, Remote Management
Don't see internet settings anywhere. Where does it aks you if you need password for internet connections?
Lurksalot
Jun 17, 2020Apprentice
- DavidtamuraJun 17, 2020Aspirant
Thanks, found it. I have to see what happens tonight at midnight. I hope this works. Do you also recommend that I click on
"I disagree" radio button on "Router Auto Firmware Update" or is there another auto update setting?
- LurksalotJun 17, 2020ApprenticeYes click, "I disagree".
I hope your issue(s) are resolved. Let us know how it goes nonetheless. - ChidoriXDJun 18, 2020AspirantI am at the part where you go into your router login-
Internet
Does your internet require login clicked
"yes"
And then
"Always on" for connection mode
But it then says "User name cannot be left blank" when I hit apply .
Any idea what to do next ?
Thanks - NewfiedroolJun 18, 2020Virtuoso
Are you PPPoE?
Who's your isp?
Newfiedrool wrote:Who's your isp?
I use Spectrum
I don't know your isp, I'm U.K. for me for example it's my email and any password as it's linked to my line.
hoping someone can pop in but if your not sure can you not contact them to verify the credentials.
Newfiedrool wrote:I don't know your isp, I'm U.K. for me for example it's my email and any password as it's linked to my line.
Oh I see, gotcha.
Yeah I've never done any configurations really with my routers before
it's just frustration that this router I have disconnects so frequent on every device. I hope that someone has an answer or I may end up changing routers/brand
Thank you for your help
- LurksalotJun 18, 2020Apprentice
I would agree that you try your ISP's username \ password, however I suggest you contact them and ask if they require credentials to connect. I wouldn't think ISP's would have such a requirement. I have Cox and it is not required, however I did have to activate my mode with them.
Edit: I did have to activate my **cable modem** with them (my ISP, Cox).
Lurksalot wrote:I would agree that you try your ISP's username \ password, however I suggest you contact them and ask if they require credentials to connect. I wouldn't think ISP's would have such a requirement. I have Cox and it is not required, however I did have to activate my mode with them.
okay I will give that a shot,
Thanks for the suggestions.
- DavidtamuraJun 22, 2020Aspirant
All fixed. No problems yet. Thanks a lot.
