Gregg00SS
Mar 02, 2021Initiate
RAX120 lost internet connection and won't reconnect, plus looks like fan stopped working
Have had the RAX120 since September of last year with absolutely no issues. Today the wife complained the internet was not working so took a look at things. Wifi signal is visible, but no internet ...
Mar 02, 2021Guru - Experienced User
The fan only runs if its needed. I don't think mine on my RAX200 has ever ran other than when it first boots up.
have you tried a simple factory reset and reinstall?
Gregg00SS
I will mess with it more when I get home from work but I did do a factory reset and had issues setting the router back up because it could not detect an internet connection.
