Kreckon
Nov 09, 2019Aspirant
RAX120 MMS Messages Not Coming Through
Got a problem and can't seem to figure it out after two weeks of researching and testing. New RAX120 router, since being installed, none of the cell phones that connect via my Wi-Fi can received...
Nov 10, 2019Guru - Experienced User
What modem are you using? make and model number help.
Are you using anytime of vpn service?
have you tried Disabling SIP ALG?
Some voice/video communication applications do not work well with the SIP ALG. Enabling this option to turn off the SIP ALG may help your voice/video applications to create/accept a call through the router.
- KreckonNov 10, 2019Aspirant
Thank you Plemans for the reply and recommendation. Tried disabling SIP ALG, as I had not tried that, but unfortunately did not work. Rebooted router after change, just in case.
As far as the modem, it is a Hitron coda-4589, currently in bridge mode. Didn’t look at the modem as a possible problem, as previous router worked fine with the same modem. Only change was installing the new RAX120.
Haven’t used or configured any VPN service since installation of new router. All VPN settings are currently default.
Thanks again for the recommendation. Willing to try anytime as wife is pushing me to revert back to old router, but really would prefer to stay with this one.
- plemansNov 10, 2019Guru - Experienced UserSomething to try?
Put the Hiltron back on router mode, disable the wifi on it, and put the rax in ap mode.- KreckonNov 11, 2019Aspirant
This solution resolved the problem, but now I have a very expensive AP. I prefer more control over my network, so I can't leave this configuration in place. At least it eilimnate the modem as the potential problem. Thanks again Plemans.
