stefanos1000
Jan 15, 2020Aspirant
RAX120 Nat loopback
Hi all,
I am wondering if this router supports NAT loopback. In the article
https://kb.netgear.com/000049578/NETGEAR-Router-support-for-NAT-Loopback
it mentions that the article applies to my router, but it doesn't seem to work
when I try to access my internal devices using my dynamic dns address from
my lan. When I try to access the devices outside the lan they work fine.
So what is going on with this?
thanks
1 Reply
- stefanos1000Aspirant
Furthermore I want to add that I am using the router behind my ISP's FTTH router
so the internet address it sees is 192.168.2.2 (get dynamically from ISP)Could that be the problem? If I set the ip manually to the one I get from my ISP then
I don't have any internet at all.
