douggold
Oct 09, 2020Follower
RAX120 new external hard drive not showing up
At the moment, I've got an old Time Capsule with a 1TB hard drive plugged into my RAX120 with an ethernet cable. The Time Capsule's wifi featuers have been turned off. I'm just using the 1TB hard d...
Oct 10, 2020Guru - Experienced User
Is it a compatible device?
https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
What format did you format it in?
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
