Mullmuzzler
Aug 16, 2024Aspirant
RAX120 Nighthawk suddenly blocked all Apple Services
First post so I apologize if I'm missing needed info. Two days ago, my roommates and I noticed none of our Apple devices that have been wirelessly connected to the same router/setup for five yea...
Aug 16, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Any other wifi devices experiencing problems?
What iOS version is on the Apple devices?
Armor, Smart Parental Controls or Circle, Traffic Meter.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Mullmuzzler
I'll check all of that when I get home tonight. I must state that absolutely nothing was changed on any devices within the last few weeks. No MacBooks, Mac Minis, iPhones, or AppleTVs were updated. The RAX120 was not updated. The Modem has worked perfectly fine for years and has not been touched other than the restarts that give a 1-2 minute temporary fix. I did put a brand new LAN cable on it and no difference. No other non-Apple wifi devices are experiencing any issues at all. The only issues are Apple Devices trying to use Apple Services. Running iOS 17.6.1 on my iPhone as I type this but had no issues before or after the update until randomly two days ago. We don't use VPNs. No Firewalls.
- FURRYe38Aug 16, 2024Guru - Experienced User
Please give feedback when you can.
FYI, been other users posting having odd problems with newer iOS version.
- MullmuzzlerAug 16, 2024Aspirant
I did absolutely nothing today on my end and suddenly all of the issues you described (which I've been having on my RAX120 for two days) are resolved according to my roommate who just tried it. Definitely frustrating.
Possible something with Apple or ISP services.
