afhvengeance
Oct 01, 2023Aspirant
RAX120 No 2.4ghz
Arrived home today and noticed a few connected devices flashing red lights at me. After a little research, realized the router is no longer broadcasting the 2.4ghz band. 5ghz is still up and working....
michaelkenward
Oct 02, 2023Guru - Experienced User
afhvengeance wrote:
After a little research, realized the router is no longer broadcasting the 2.4ghz band. 5ghz is still up and working. The 2.4 ghz light is on and blinking on the unit.
Is it just some devices that lose the wifi?
By design the RAX120 uses Smart Connect and doesn't have separate SSIDs for 2.4 GHz and 5 GHz, so it isn't always easy to work out if they are both broadcasting.
afhvengeance
Oct 02, 2023Aspirant
Smart connect isn't on, and it has always broadcasted two different SSIDs, the network name, then the network name-5G. It completely stopped broadcasting the former, meaning devices that could see it previously and connect to it, can no longer do so. If I go to the attached devices page, all of the connected devices are either wired or on the 5G band.
- michaelkenwardOct 02, 2023Guru - Experienced User
afhvengeance wrote:
Smart connect isn't on, and it has always broadcasted two different SSIDs, the network name, then the network name-5G.OK. It was important to fill that missing gap in the details you provided.
Another missing detail, have you also checked that the RAX120 is set the broadcast the 2.4 GHz SSID? That is also something that you can toggle in the GUI.
You said earlier that you had reset the router. Did you check that you had restored the earlier settings? Is Smart Connect still off?
- afhvengeanceOct 02, 2023AspirantYes it is set to broadcast. Like I said in the original post, it was all working as it should, randomly came in one day and the 2.4 was gone.
afhvengeance wrote:
Like I said in the original post, it was all working as it should, randomly came in one day and the 2.4 was gone.Unfortunately, we have seen cases of routers suddenly losing their settings and reverting to the defaults. This can happen after a power cut.
That's why it is important to look under the hood and see what is going on.
Looks like you may have to replace the router. Depending on where you are, it may be possible to make a warranty call. The US may be limited to one year, but some countries have better consumer protection.
Have you played with guests network to see if that comes to life?
