MrxAD81
Jul 17, 2021Follower
RAX120 no Internet Access via LAN
Hi,
I have configured my Telekom Router as DSL Modem and connected the RAX120 via LAN Port 4.
In RAX120 I have enabled open NAT and WAN VDSL Uplink 7.
Everything works fine without the Apple TV 4K. It is reachable via AirPlay but Netflix is not working, it does not get access to the internet.
If I connect the Apple TV via WLAN everything works fine.
Do I need to configure something for IPTV?
1 Reply
- Christian_RNETGEAR Employee Retired
Hello MrxAD81,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
