bmoorman
Dec 25, 2021Guide
RAX120 no Web UI
Hello, I can't get access to my Nighthawk anymore. The Web config is not accessable and I get a connection-refused by the browser. This is over the local LAN. I have tried powercycling but that didn...
bmoorman
Dec 25, 2021Guide
The router is connected to the internet via a fiber gateway/modem, so I do have a double nat issue. But this setup has worked fine before.
I tried both 10.0.0.1 which is the ip of the router I set it to. I have also tiried via routerlogin.
The Nighthawk does not show its web interface (no connection), I can ping it, I can get new ip address on its guest Wifi. A new phone can't get access to it via LAN Wifi only on guest wifi. Weird.
Dec 25, 2021Guru - Experienced User
Have you tried factory resetting it and then during the install, put its ip address into the primary gateway's dmz?
