bmoorman
Dec 25, 2021Guide
RAX120 no Web UI
Hello, I can't get access to my Nighthawk anymore. The Web config is not accessable and I get a connection-refused by the browser. This is over the local LAN. I have tried powercycling but that didn...
bmoorman
Dec 29, 2021Guide
no luck with tftp, altough it updated fine I did not get the Web config back.
Will try nrmpflash tomorrow and I report. But it is really weird. The router seems to do everything ok except running the webserver inside.
bmoorman
Dec 30, 2021Guide
Ok. Finally got the Web UI back!
I decided to flash with tftp using an older version V1.0.0.64. This worked.
After that I was able to restore the config using a backup of the config.
I also succesfully updated the version to the latest v1.2.3.28. Thanks for the pointers plemans
- plemansDec 30, 2021Guru - Experienced User
Glad it worked for you even though you had to go through the work around!
