blackhawkpr
Mar 11, 2019Tutor
RAX120 not playing nice with new Samsung Galaxy S10
Just received the phone and it simply won't connect to the network unless I set a static IP on the phone. When it manages to connect with the static IP, speeds are abysmal at 100 mbit or under (link ...
- Apr 06, 2019That is correct, AX is enabled and working with S10 plus.
blackhawkpr
Mar 11, 2019Tutor
Disabling AX fixes everything, except now it's just a glorified AC router.
schumaku
Mar 12, 2019Guru - Experienced User
Tha'ts the fun when going (b)leading edge technology - some interoperability issues are easily predictable. Here it's Wi-Fi 6 (not WPA3 and I understand you had disabled WPA3 already for a test).. Could be a problem on both ends. Netgear has to investigate, not much we can do as end users (even if highly tech minded - most of us don't have access to Wi-Fi 6 capable wireless analyzers). File a support ticket if you are within the full support time of your AX12.
