blackhawkpr
Mar 11, 2019Tutor
RAX120 not playing nice with new Samsung Galaxy S10
Just received the phone and it simply won't connect to the network unless I set a static IP on the phone. When it manages to connect with the static IP, speeds are abysmal at 100 mbit or under (link ...
- Apr 06, 2019That is correct, AX is enabled and working with S10 plus.
davecar
Apr 04, 2019Tutor
I was having the exact same issue and I fixed it. After working with tech support for almost 2 hours it couldn't be resolved so they sent me a new router. It had the same issue right out of the box, so I just went back and did some troubleshooting myself with the older one. There is a new firmware out 1.0.0.84 which allows you to select a "DFS" channel under the 5Ghz advance settings. Once I did that it all worked!
- schumakuApr 06, 2019Guru - Experienced User
Up to now, the workaround for these AX clients was to disable the AX mode on the router (making it an expensive AC device). Can you confirm this is no longer required, and you didn't had to disable AX on the replacement device? This would be some good progress for the interoperability!
- blackhawkprApr 06, 2019Tutor
I can confirm that the latest firmware (1.0.0.84) works fine with my S10+ without having to turn off the AX feature on the router.
- davecarApr 06, 2019TutorThat is correct, AX is enabled and working with S10 plus.
- davecarApr 06, 2019TutorYou can now also select 160H and works fine on any channel.
