blackhawkpr
Mar 11, 2019Tutor
RAX120 not playing nice with new Samsung Galaxy S10
Just received the phone and it simply won't connect to the network unless I set a static IP on the phone. When it manages to connect with the static IP, speeds are abysmal at 100 mbit or under (link ...
- Apr 06, 2019That is correct, AX is enabled and working with S10 plus.
schumaku
Apr 06, 2019Guru - Experienced User
davecar wrote:
There is a new firmware out 1.0.0.84 which allows you to select a "DFS" channel under the 5Ghz advance settings. Once I did that it all worked!
Up to now, the workaround for these AX clients was to disable the AX mode on the router (making it an expensive AC device). Can you confirm this is no longer required, and you didn't had to disable AX on the replacement device? This would be some good progress for the interoperability!
blackhawkpr
Apr 06, 2019Tutor
I can confirm that the latest firmware (1.0.0.84) works fine with my S10+ without having to turn off the AX feature on the router.
