sjbhh
Dec 30, 2023Apprentice
RAX120 on Firmware 1.2.9.52 keeps freezing every other day
Since updating to 1.2.9.52 the RAX120 freezes on a regular basis every few days. If that happens no connection whatsoever to the router is possible. The app does not find it and nor Windows or MacO...
- Jan 01, 2024
Thats ok to. Up to you if you want to give feedback or not. Your stutf. Just trying to help out here and see if we can narrow down the issue. I put mine online:
Lots of uptime:
I guess I might be best if you make contact with NG support and let them help you out. I'll not bother you any more.
This user foudn that a factory reset and setup from scratch and not enabling Armor solved his router hangs:
Good Luck.
sjbhh
Jan 01, 2024Apprentice
I might be wrong here but you can not be seriously asking to do all of this.
I am not running Netgear Development Team.
I am a user and if I spend north of USD 500,- on a router I think I can expect that to work or at least to have minimum support. Looks like I am wrong at least on that.
Jan 01, 2024Guru - Experienced User
Lots of uptime:
Good Luck.
