Freebird317
Feb 14, 2020Luminary
RAX120 Open Ports On Internet
Does the RAX120 have a firewall? I scanned my ip and found lots of open ports. IP is scrubbed. Discovered open port 21/tcp on 4.4.4.4 Discovered open port 80/tcp on 4.4.4.4 Discovered open...
Killhippie
Feb 16, 2020Prodigy
using shields up I have total stealth on the fiurst 1000 ports, have you factory reset your router at after any updates? What did you use to check ports?
