Freebird317
Feb 14, 2020Luminary
RAX120 Open Ports On Internet
Does the RAX120 have a firewall? I scanned my ip and found lots of open ports. IP is scrubbed. Discovered open port 21/tcp on 4.4.4.4 Discovered open port 80/tcp on 4.4.4.4 Discovered open...
Killhippie
Feb 16, 2020Prodigy
is this an app on your computer scanning within your network? In which case it seems to be opening ports to connect to scan me most odd and id would remove it. Try shields up as that scans from outside the firewall, not from within.
Freebird317
Feb 16, 2020Luminary
I am using nmap scanning my IP from work
- KillhippieFeb 16, 2020Prodigy
I think you are hiitting your ISP first thats why see this post;
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Open-Ports-WAN-side-on-R7000-Router/td-p/1203861
Try scannng your IP from home using shileds up, I tried scanning my IP and the first1000 ports on the RAX120 are true stealthed
