Freebird317
Feb 14, 2020Luminary
RAX120 Open Ports On Internet
Does the RAX120 have a firewall? I scanned my ip and found lots of open ports. IP is scrubbed. Discovered open port 21/tcp on 4.4.4.4 Discovered open port 80/tcp on 4.4.4.4 Discovered open...
Freebird317
Feb 16, 2020Luminary
I am using nmap scanning my IP from work
Killhippie
Feb 16, 2020Prodigy
I think you are hiitting your ISP first thats why see this post;
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Open-Ports-WAN-side-on-R7000-Router/td-p/1203861
Try scannng your IP from home using shileds up, I tried scanning my IP and the first1000 ports on the RAX120 are true stealthed
