W3I
Aug 09, 2020Tutor
RAX120 piss of **bleep**
No help at all, no single one of the support team can help me, give my money back please!
Aug 09, 2020Guru - Experienced User
This is the community forum. Where members of the public help others out. We're not netgear.
You'd need to go through support if you want to return your product.
otherwise, if you want help, we're here for that.
What issues are you having? (in details since we aren't there to see whats going on)
what modem/gateway are you connecting to?
What firmware is on the router?
W3I
Aug 09, 2020Tutor
RAX120 keeps offline
Router Firmware Version V1.0.1.122
I try to reboot, factory reset, turn it off and turn back on after half an hour, update to the latest firmware
I called my internet provider 5 times to make sure there is nothing wrong with my line and NBN router modem. I even bought 3 different brand internet cable cat 6 cat 7 and cat 8 to do the test, the problem still there.
The router itself is warm, and the fan never run, now my router is still in hardware warranty, but my three month support is expired. I couldn’t even talk to support team, they just want more money. That is so bad. I have no ideal what should I do now.
Also I saw lot of people have this problem, and it wasn’t getting fixed, I don’t know, it is getting worse right now(offline issue). I’m so angry. Paid $600 for garbage.
- plemansAug 09, 2020Guru - Experienced User
W3I wrote:
RAX120 keeps offline-----its saying its offline? wifi isn't connecting? hardwired devices not connecting? again, details are what helps. What are the leds doing? what is actually going on? Be specific. We aren't there to see whats happening, what you're doing, your setup, or even how you're attempting to access it.
I called my internet provider 5 times to make sure there is nothing wrong with my line and NBN router modem----Which router modem is this? Its kind of a key point if you're in a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
Also I saw lot of people have this problem,---Again, its tough to say if you're having the same problem as others without details of exactly whats happening. and it wasn’t getting fixed, I don’t know, it is getting worse right now(offline issue). I’m so angry. Paid $600 for garbage.thank you for your respond, could you please help me how could I return or replace my router without talking to support team-----You have to go through support to replace it. Potentially you could return it where you bought it from but that'd be dependant on their return policy
- W3IAug 10, 2020Tutor
Phone app shows me offline, all my wifi and cable connection is no internet, router websites shows me no internet connection. I have to rebot to get internet back on
Modem is NBN modem hybrid fibre coaxial (HFC)
So it is random offline, router itself is lost connection, I went to app router setting, then internet port. shows me no External ip address, no gatway ip address, no subnet mask, no dns server all 0.0.0.0, I have to reboot router to get all those back to normal- michaelkenwardAug 10, 2020Guru - Experienced User
We are none the wiser when it comes to knowing what this modem is.
That tells us about the technology, not the make and model.
W3I wrote:
I called my internet provider 5 times to make sure there is nothing wrong with my line and NBN router modem.What is that NBN modem? And your ISP?
Getting stuff to work on NBN can be a nightmare. The good news is that a lot of people have already grappled with the challenge. So there's a lot of past experience that you can draw on. For example:
Search - NETGEAR Communities – D6300 NBN
and
Search - NETGEAR Communities – RAX120 NBN
You can try narrowing that down by plugging the name of your ISP into the search. Some ISPs have especially exotic configurations.
The problem is that NBN comes in many flavours, effectively it just means "Australian Internet".
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
Start by checking for your type of NBN.
While Netgear lists all manner of things as being "compatible" with NBN in that article, in reality this often means that the device will work as a router. You have to bypass the modem bit and use something else as a modem. Sometimes it is just the NBN box that your ISP installed.
Here's a good place to start looking for local expertise:
Remember, if you are transferring your modem/router from one type of NBN to another it is a good idea to reset the modem/router to that it forgets in past settings carried over from the old service.
Good luck, you may need it.
thanks for your help, I'll have a look
