siliconglen
May 16, 2021Tutor
RAX120 problems on 2.5GHz
Most of my devices use 5Ghz however a couple of legacy devices use 2.5Ghz. The 2.5Ghz don't have the hardware to connect at 5Ghz Router was upgraded through the app to V1.2.1.22 firmware recently...
- Jun 06, 2021
This is no longer working. Have the latest firmware, set the 2.5Ghz band to no password and still couldn't get a connection.
Then set the password and the invalid password errors reappeared. I must have a reliable 2.5Ghz as I have devices which only use this band. Also, I don't appreciate my time being wasted and in the unlikely event I ever work in an office again, I'm not having my family hindered by unreliable internet while I'm out the house.
The netgear support is poor and offers nothing except a robot reponse and "call this number" after 90 days, offering no free options for anyone with a speech issues or who doesn't want to take up time during the valuable working day when I am facing customers.
Therefore and on the basis of multiple independent reviews I'm going for the ASUS RT-AX86U
%age of 1,2,3 star reviews on Amazon for this product Vs the RAX120: 8% Vs 23%
1 star reviews 3% Vs 12%
Rated Excellent by PC Mag: https://uk.pcmag.com/wireless-routers/129217/asus-rt-ax86u-ax5700-router
Rated best for the money by CNET: https://www.cnet.com/home/internet/asus-rt-ax86u-wi-fi-6-router-review/
Favourite Standalone Router by Tom's guide: https://www.tomsguide.com/uk/reviews/asus-rt-ax86u
Impressive by Techradar https://www.techradar.com/uk/reviews/asus-rt-ax86u
Highly rated by Dong https://dongknows.com/asus-rt-ax86u-ax5700-gaming-router-review/
I need a relatively up to date router that is secure and reliable. Netgear isn't reliable.
Razor512
May 16, 2021Prodigy
Keep in mind that some devices to not support mixed WPA2 and WPA3 modes, where if they have compatiblilty issues, they will endlessly try to connect or simply find whatever password you enter as wrong.
thehypnootoad
May 16, 2021Luminary
With my 2.4 ghz devices I personally reserve the ip address as they just struggle to connect ... but since this update my google hubs keep dropping connection and my s20plus 5g keeps giving me authentication error messages till I make a static ip on the phone.
- siliconglenMay 18, 2021Tutor
Printer only connects on 2.5Ghz and is giving me an error "MAC address may be filtered" error code E-6. I don't have MAC filtering on.
- james1795May 19, 2021Aspirant
Make sure to disable 20/40 coexistence. Also under wireless just do WPA2 and see if that works for you. I had to do this to mine so my wireless printer would connect on the 2.4 band.
- mariosuper47Jun 02, 2021Initiate
Firmware update V1.2.1.22 caused this yesterday on my router. I didn't realize that the update had occured until nothing else I tried worked. Everything had been working fine until yesterday. But then 2.4 Ghz wifi was dead even though the lights on the router were flashing as if the band was active. All my home smart connections were disconnected and I couldn't switch them to 5 GHz
Finally I checked firmware and found the firmware version above had automatically updated. I then unchecked the box for automatic update of firmware and rolled back to the next oldest version of firmware.
Viola! Everything works again. I have had this sort of thing happen previously with other Netgear routers but, up until now, the RAX120 had been rock solid.
