Moshel
Dec 17, 2019Aspirant
RAX120 rejects WiFi connection and responds Wrong password message
Hello I just connected my new WiFi router RAX120 Firmware V1.0.1.108 using laptop with win10. I have succeeded connecting several WiFi devices (PC, Android tablet, Android phone, IPhone etc.). I fai...
Christian_R
Dec 18, 2019NETGEAR Employee Retired
Hello Moshel,
You may need to reset the TV if that's and option.
Christian
Moshel
Dec 18, 2019Aspirant
Thank you Christian
The TV box is an android external to the TV (connected by HDMI cable). I have rebooted it several times and even turned it off and on. Nothing helped. Only turning off the security (no password) helped. The same TV box was connected to my previous router with password and worked fine.
