Moshel
Dec 17, 2019Aspirant
RAX120 rejects WiFi connection and responds Wrong password message
Hello I just connected my new WiFi router RAX120 Firmware V1.0.1.108 using laptop with win10. I have succeeded connecting several WiFi devices (PC, Android tablet, Android phone, IPhone etc.). I fai...
steih
Dec 20, 2019Initiate
Purchased rax120 about 3 weeks ago. Had the same problem when trying to connect older devices on 2.4ghz band. Changed auto channel setting in rax120 to a hardcoded channel (in my case 6) and problem went away. Everything has been running smoothly and fast since.
- MoshelDec 28, 2019Aspirant
Hi Steih
Thank you. Your solution did not work for me (fix channel). On the other hand without password security it works fine in my case. I have found another solution: Setup my old router as a bridge and connected it to the TV box (wired to the bridge - old router).
