Moshel
Dec 17, 2019Aspirant
RAX120 rejects WiFi connection and responds Wrong password message
Hello I just connected my new WiFi router RAX120 Firmware V1.0.1.108 using laptop with win10. I have succeeded connecting several WiFi devices (PC, Android tablet, Android phone, IPhone etc.). I fai...
steih
Dec 20, 2019Initiate
Purchased rax120 about 3 weeks ago. Had the same problem when trying to connect older devices on 2.4ghz band. Changed auto channel setting in rax120 to a hardcoded channel (in my case 6) and problem went away. Everything has been running smoothly and fast since.
Moshel
Dec 28, 2019Aspirant
Hi Steih
Thank you. Your solution did not work for me (fix channel). On the other hand without password security it works fine in my case. I have found another solution: Setup my old router as a bridge and connected it to the TV box (wired to the bridge - old router).
