fcano42
May 15, 2020Guide
RAX120 repeatedly reboots
Router repeatedly reboots. Had FW 1.0.1.108 (i recall) and now 1.0.1.122 and still the same issue. Wrote a little perl script to ping the router and report when it is not where. I see that it goes...
Christian_R
May 20, 2020NETGEAR Employee Retired
Hi fcano42 and dcinca,
May you try performing a factory reset and running through the setup assistant again.
Christian
