fcano42
May 15, 2020Guide
RAX120 repeatedly reboots
Router repeatedly reboots. Had FW 1.0.1.108 (i recall) and now 1.0.1.122 and still the same issue. Wrote a little perl script to ping the router and report when it is not where. I see that it goes...
Bry2001
Jun 08, 2020Initiate
I am having the same issue, router is rebooting randomly over the last few days. I am on 1.0.1.122
Is this a firmware issue?
- Christian_RJun 11, 2020NETGEAR Employee Retired
Hello Bry2001,
Have you had a chance to perform a factory reset and run through the setup assistant again?
Christian
- Bry2001Jun 11, 2020InitiateYes hasn’t helped.
- Christian_RJun 12, 2020NETGEAR Employee Retired
Hi Bry200 - Thanks for confirming. May you revert to the previous firmware version and let me know if your issue persists.
https://kb.netgear.com/000061718/RAX120-Firmware-Version-1-0-1-118-Hot-Fix
Christian
