fcano42
May 15, 2020Guide
RAX120 repeatedly reboots
Router repeatedly reboots. Had FW 1.0.1.108 (i recall) and now 1.0.1.122 and still the same issue. Wrote a little perl script to ping the router and report when it is not where. I see that it goes...
Christian_R
Jun 11, 2020NETGEAR Employee Retired
Hello Bry2001,
Have you had a chance to perform a factory reset and run through the setup assistant again?
Christian
Bry2001
Jun 11, 2020Initiate
Yes hasn’t helped.
- Christian_RJun 12, 2020NETGEAR Employee Retired
Hi Bry200 - Thanks for confirming. May you revert to the previous firmware version and let me know if your issue persists.
https://kb.netgear.com/000061718/RAX120-Firmware-Version-1-0-1-118-Hot-Fix
Christian
- dcincaJun 21, 2020Apprentice
I reverted to 118, no reboot for 4 weeks.
I only noticed wifi signal drops from my phone for 1-2 sec, about twice a day. But no drops from my computer. It's maybe caused by the phone wifi chip compatibility.
- terencemokSep 09, 2020Aspirant
I tried to revert to 118 hotfix, and we had 2 reboots today.
- CockneyDec 10, 2020Apprentice
Router Firmware Version V1.0.2.136
From the logs:
[Time synchronized with NTP server] Thursday, December 10, 2020 09:20:40
[Internet connected] IP address: xxx.xxx.xxx.xxx, Thursday, December 10, 2020 09:20:32[Initialized, firmware version: V1.0.2.136] Thursday, December 10, 2020 09:20:29[Time synchronized with NTP server] Sunday, December 06, 2020 12:38:12[Internet connected] IP address: xxx.xxx.xxx.xxx, Sunday, December 06, 2020 12:38:10[Initialized, firmware version: V1.0.2.136] Sunday, December 06, 2020 12:38:10Reboots about every 4 days and resets the logs. I'm having the logs sent to me every hour.
