fcano42
May 15, 2020Guide
RAX120 repeatedly reboots
Router repeatedly reboots. Had FW 1.0.1.108 (i recall) and now 1.0.1.122 and still the same issue. Wrote a little perl script to ping the router and report when it is not where. I see that it goes...
Cockney
Jun 29, 2021Apprentice
Send it back. You'll never fix it. Netgear couldn't fix mine in over four months, including a replacement. Just my 2c.
Finckster
Sep 15, 2021Initiate
Mine too, it reboots at random. I have plugged it sraight into the wall, factory reset it like 4 times and sent it back for a replacment. got the new replacment and same story it too reboots. but today got a firmware update V1.2.2.24 lets see if this works. otherwise I will send this back and get a completley different model/Brand.
- FincksterSep 19, 2021Initiate
I just renerned the new same model Router as it too did the same.
I purchased a different model.
