fcano42
May 15, 2020Guide
RAX120 repeatedly reboots
Router repeatedly reboots. Had FW 1.0.1.108 (i recall) and now 1.0.1.122 and still the same issue. Wrote a little perl script to ping the router and report when it is not where. I see that it goes...
ericwood73
Oct 26, 2021Initiate
I have a RAX120 v2 and having the same problem. I replaced the router after havning the same issue with the the first router and I'm still seeing the issue. I also changed ISP between the routers (from AT&T to XFinity). I noticed that there were some DoS reports in the log coicindent with the reboots. I tried disabling the DoS protection under WAN settings and it did not fix the problem. I have tried firmware 1.2.1.22 and 1.2.0.16. I could not install 1.0.2.136 as it said the firmware is invalid. Called support and they have escalated to Tier 3. I think we're giving up on Netgear.
