fcano42
May 15, 2020Guide
RAX120 repeatedly reboots
Router repeatedly reboots. Had FW 1.0.1.108 (i recall) and now 1.0.1.122 and still the same issue. Wrote a little perl script to ping the router and report when it is not where. I see that it goes...
sespino2
Dec 07, 2021Initiate
I am on my second Nighthawk router and am experiencing the same issues. The first 2 days everything works fine but now is constantly rebooting about 1-2 times a day. The support team has been no help just the constant process to do a factory reset and try various channels until one might not have issues. Did anyone find a solution to the nighthawk router rebooting on its own?
Cockney
Dec 07, 2021Apprentice
My final solution was to buy a TP-Link. No issues since. Netgear can go .......... themselves.
sespino2 wrote:I am on my second Nighthawk router and am experiencing the same issues. The first 2 days everything works fine but now is constantly rebooting about 1-2 times a day. The support team has been no help just the constant process to do a factory reset and try various channels until one might not have issues. Did anyone find a solution to the nighthawk router rebooting on its own?
