fcano42
May 15, 2020Guide
RAX120 repeatedly reboots
Router repeatedly reboots. Had FW 1.0.1.108 (i recall) and now 1.0.1.122 and still the same issue. Wrote a little perl script to ping the router and report when it is not where. I see that it goes...
Cockney
Dec 08, 2021Apprentice
All good advice. However with regards to the RAX120. Mine was only a few months old when it started problems. I had it replaced and the replacement still had the same issues. AND their warranty is only 90 days for hardware whcih totally sucks.
Dec 08, 2021Guru - Experienced User
Have you tried AP mode on the RAX connected to your upstream router?
