fcano42
May 16, 2020Guide
RAX120 repeatedly reboots
Router repeatedly reboots. Had FW 1.0.1.108 (i recall) and now 1.0.1.122 and still the same issue. Wrote a little perl script to ping the router and report when it is not where. I see that it goes...
Cockney
Dec 08, 2021Apprentice
That boat passed a long time ago.
mudbone
I had versions 1 and 2 and returned version 2. Version 1 is setup now as an access point and has been for quite a while. It is relatively stable after some firmware updates but I never could get version 2 to work without rebooting all the time. Support will just keep you dangling along until the return period elapses then you will have a 400 dollar paper weight. My suggestion is if you have version 2 return it immediately. The two versions are different and the firmware developer does not know what they are doing. I truly do not think its a hardware problem and I strongly suggest that you don't wait for a firmware fix. I will never buy another Netgear router again after my experience with these routers. I will take a chance on their cable modems but that is it.
