Mjohnson4580
Mar 14, 2020Tutor
Rax120 Reset
I have a Rax 120 that is running .118 firmware. Last night it just rebooted and reset itself all by itself. Has this happened to anyone else running this firmware?
Newfiedrool
Mar 15, 2020Virtuoso
Do you mean it reset ie. you lost all internet settings or do you mean it just rebooted and failed to connect to the internet.
ive not had this and my friend has not experienced this both using 118 which we did a rest afterwards.
Did you reset after installing 118?
if it continues to happen I would contact Netgear.
