Mjohnson4580
Mar 14, 2020Tutor
Rax120 Reset
I have a Rax 120 that is running .118 firmware. Last night it just rebooted and reset itself all by itself. Has this happened to anyone else running this firmware?
BKSD
Mar 18, 2020Tutor
I wanted to give an update. I installed the 118 hotfix firmware and restarted my router 3 days ago. My router hasn't restarted or dropped WiFi since I updated the firmware to the 118 hotfix. Before my router was dropping WiFi once a day and I would have to restart the router to get WiFi back up. Since the firmware update this hasn't happened for me.
I have noticed that some replies in this thread recommend doing a factory reset after you update the firmware to 118. Wouldn't that remove the update the hotfix update? Its not necessary to do a factory reset after you install the new firmware.
- NewfiedroolMar 18, 2020Virtuoso
How does a reset remove firmware updates? You are simply resetting the router to clear it of low level stuff.
Resetting does not remove firmware, if it did your router would be dead in the water.- BKSDMar 18, 2020TutorAn earlier reply suggested doing a factory reset after you updated the firmware to 118. I was stating that doing a factory reset after you update the firmware would remove the firmware update. But doing a "restart" of the router after the firmware update would be fine.
to help understanding a why a reset helps I'll post this link again for you to have a read over .https://www.snbforums.com/threads/faq-nvram-and-factory-default-reset.22822/
resetting a router does not remove a firmware update. Firmware could include security updates and drivers which replace what's on your router. They overwrite the code and a reset can not remove what's been updated.
