Mjohnson4580
Mar 14, 2020Tutor
Rax120 Reset
I have a Rax 120 that is running .118 firmware. Last night it just rebooted and reset itself all by itself. Has this happened to anyone else running this firmware?
SubLogic
Mar 19, 2020Aspirant
I updated to 118 yesterday and it worked for about 8 hours, today the router completely reset itself to factory defaults and I had to set it back up again. Even the hardwired LAN ports lost internet.
I've had this router a little over a year and it's been junk. I have to reboot it just about everyday. I have new hope with every firmware update that they will have the issue resolved but it keeps getting worse.
Paid $400 for this router and it is great when its working which is about 75% of the time. Router has been very unstable requiring reboots and resets quite often. Unit usually fails overnight so I wake up to no internet.
I think its time for me to shop for a new router.
Mjohnson4580
Mar 19, 2020Tutor
118 defintly has something wrong with it. Im on 114 right now and sticking with that. Netgear has a hard time with firmware. My year and a half long trail with netgear i believe is coming to an end.
- SubLogicMar 19, 2020Aspirant
Totally agree this is my first and probably last Netgear router. Looking at Linksys MX10 as a replacement.
- NewfiedroolMar 19, 2020Virtuoso
SubLogic wrote:Totally agree this is my first and probably last Netgear router. Looking at Linksys MX10 as a replacement.
Ive seen for the last year you have not posted so I take it it's been working well. Does yours have wall mounts?
- SubLogicMar 19, 2020AspirantIt hasn’t been working well I’m just getting good and turning off and back on every time it drops connections.
Reboot restores connection for a day or if I’m really lucky it might go up to 5 days without a problem.
So I’ve just learned to live with a quick reboot every couple of days.
It’s not wall mounted but centrally located in the home in an open area. - NewfiedroolMar 19, 2020Virtuoso
Does yours have wall mounts, should be underneath?
