mesencephalon
Aug 08, 2019Guide
RAX120 router - SSD file transfer slow with 5gbe ethernet connection
Hello everyone, I recently purchased 1. RAX120 AX6000 router (connected to CM1200 cable modem with monoprice CAT8 ethernet cable) 2. 15 feet Monoprice CAT8 ethernet cable connects the RAX120 ro...
- Aug 14, 2019Just to close the topic.
I tested large file transfer on network with another ssd and top speeds are same around 150mb/sec and there was no speed slow down on the way.
I realized that speed slow down problem is related with my current ssd. I tested my current ssd with a direct connection to my computer and shows the same gradual slow down.
As a result, this router is able to provide around 150mb/sec with fastest hard drives without any geadual slow down. If anybody experience gradual slow down during large file transfer, I recommend them to check their hard drives.
mesencephalon
Aug 14, 2019Guide
michaelkenward
Aug 14, 2019Guru - Experienced User
Good feedback.
Sound advice.
