rax120_rax80
Mar 08, 2020Apprentice
RAX120 Router Random Disconnects
Hey everyone, I know that I'm not the only one with problems on the Nighthawk WiFi 6 devices, but thought I'd post my most recent headache. My hardware consists of a Motorola MB8600 DOCS 3.1 modem w/...
rax120_rax80
Mar 09, 2020Apprentice
The router stayed up all night for about 8 hours and then the same symptoms occured once I logged into my laptop and started checking emails for about 5 minutes. I attempted to login to the RAX120 and it would not accept my username and password... I attemtped a number of times and I was not fat fingering, because I was pasting the password from my PW database. I logged into the RAX80 just fine without any issue. Nonetheless, I just reset my router back to factory and the issue still occured after it came online with a default config. WTH?!?!? Is my modem hosed and causing me the problem? The logs in the modem have nothing telling and only a couple status messages. Possibly it's a coincidence and I wasn't being patient. Eitherway, I reapplied my RAX120 config from a backup and the connections are up again.
Anyone out there have any ideas? Are these Nighthawks trash like the community has been evangalizing over the past year? Or am I just a fool? Even though I've managed numerous other network devices from Cisco, Brocade, Linksys, TP-Link, Apple, and even Extreme Networks without ever seeing an issue like this...
rax120_rax80
Just an update. After re-applying my configuration this morning the network has been stable since. However, I did disable all device MAC addresses, except for my laptop, via the security ACLs as well. About an hour back I enabled 3x IP cameras, a security NVR, and my alarm system gateway. So far so good. Possibly something on my network is being a bad neighbor after an automagic FW update the night before. I'll find out sooner or later.
- rax120_rax80Mar 10, 2020Apprentice
The issue is back! The modem ran well all day yesterday, so at about 10pm I decided to allow a few more devices. I allowed an Amazon cloud cam, a thermostat, 5 light bulbs, and 4 smoke detectors. Everything ran until about 1am and the issue resurfuced. Here's the interesting part. If I connect my phone via LTE, I am able to communicate with my alarm system that is physically connected via a CAT5e cable and to the light bulbs that are on the 2.4GHz guest network. However, the thermostat and smoke detectors that are on the non-guest WiFi network are not online. I connected my laptop once again to the non-guest WiFi and I can ping external IP addresses, but I cant resolve hostnames/URLs. The same occurs on my phone or other devices connected to that network WiFi network. I connected my laptop to the guest 2.4GHz network, but I still couldn't resolve anything to the routers DNS. The next time it happens I'll have to connect my laptop via a physical cable to see if I can get DNS resolution, but I'm not optimistic since my streaming TV device didn't work. So here's a few questions.
Why are the light bulbs accessible from outside, inbound to the network when they are on the internal 2.4GHz guest network?
Why is the security system accessible from outside, inbound to the network when it's physically plugged with a CAT5e cable network?
This is getting very tiresome though... Everything functioned wthout an issue for a few months and no changes were made. Then on Sunday morning, it all went to hell in a handbasket.
Christian_R What is Netgear doing for customers? After 90 days you are stuck with no support and a paperwieght cuz of poor FW code.- TopologyMar 10, 2020Virtuoso
Rax120_rax80, did you have an opportunity to install the RAX120 beta firmware (see message #3 above) – and, did it improve the situation you are experiencing?
Per the site, the only version in the Security Hotfixes (Beta Firmware) is 1.0.1.118 which is also in the Firmware and Software Downloads section as well. I upgraded to 1.0.1.118 after having the issue occur on 1.0.1.114 and I have been testing with .118 since. Unless there is another beta FW I'm not aware of, I'm running the latest.
Here's another update in the saga. The issue occured again about 9am this morning after I reset the RAX120 a little before 8am. The only things allowed network access were the devices running all day yesterday with no issue (WiFI IP security cams, physically connected security NVR and alarm system gateway, laptop via WiFi) and the WiFI bulbs that were functional this morning. However, I did enable the Amazon Cloud cam to swap it to the guest network for testing when the RAX120 went bonkers. It could be a coincidence, but it could be a problematic device. It's currently blocked via MAC on the router, but I'll test re-enabling that one device later if I have some stability for the entire day.
Anyway, I tested/verified the following when the RAX120 was in it's zombie state.
* Connected laptop directly to the RAX120 via CAT5e, DNS lookups succeeded when choosing external DNS servers (75.75.75.75, 8.8.8.8, etc), pings to IP addresses internally within the NAT and externally on the web succeeded, DNS lookups when choosing the RAX120 as a DNS server failed, pings to external hostsname on the web failed (as expected since DNS on the RAX120 is failing)
* ARP table on my laptop took an extrememly long time to populate, but it did list all the device MACs allowed access on the RAX120.
* Netstat from the laptop wasn't showing any socket connections, which was expected.
