rax120_rax80
Mar 08, 2020Apprentice
RAX120 Router Random Disconnects
Hey everyone, I know that I'm not the only one with problems on the Nighthawk WiFi 6 devices, but thought I'd post my most recent headache. My hardware consists of a Motorola MB8600 DOCS 3.1 modem w/...
rax120_rax80
Mar 12, 2020Apprentice
Code .108 stopped resolving DNS requests at 1am this morning. It made it about 7 hours. Below is a summary of what we’ve seen.
- After 3/1 many users experienced their network devices being disconnected
- It was determined that internal and external hosts could be reached via IP, but DNS in the RAX120 was not functioning
- The problem occurs when DNS servers are set both statically or dynamically in the router.
- The problem occurs regardless of the DNS servers set statically in the router.
- The problem occurs in code levels .108 through .118
- The problem occurs again after a factory reset
- The time between failures varies and the temporary fix is to restart the router (or dnsmasq service)
Since users were hit with this bug without upgrading or making change to their configuration prior to the impact, this feels like a time bomb bug in the code. netgear Are you going to assist your user base? We're hearing a lot of crickets.
HanzJ
Mar 12, 2020Guide
rax120_rax80, I was going to respond in a similar manner, but.....fanboys.
I really wanted this to work, but my ASUS RT-AX88U arrived this morning and is in service now. Best of luck.
- TopologyMar 12, 2020Virtuoso
Rax120_rax80, to clarify, when you say that “the problem occurs again after a factory reset,” do you mean that “random disconnects” occur when the RAX120 is in a factory reset state, with all router options having their default values?
- rax120_rax80Mar 12, 2020Apprentice
Good question. When I said the problem occurs again after a factory reset, the DNS failure that is the root of the issue occurs again. Although, the caveat is I re-apply my configuration from a backup. I haven't left the RAX120 in the default factory configuration, because I have a bunch of clients and it would take e an hour to manually setup the MAC filter again. I can give a factory reset a go and leave the settings default to see if it is any better.
The one thing that stands out to me is that no settings changed for a month before the random DNS failures. Now it's all the time. I would allude it isn't the non-default settings unless there is a time bomb in a particuar setting.
- NewfiedroolMar 12, 2020Virtuoso
Try it without the saved config, using one can bring back issues which let's hope may have been your issue in this case or a shortcut elsewhere maybe.
I've not experienced your issue and I'm also running a similar setup but would probably say the RAX80 might not be the best product for your needs even if it's a freebie and not in use.
Try it without any saved config and with just basic devices connected and slowly add devices at length maybe to see if an issue rears it's head.
