rax120_rax80
Mar 09, 2020Apprentice
RAX120 Router Random Disconnects
Hey everyone, I know that I'm not the only one with problems on the Nighthawk WiFi 6 devices, but thought I'd post my most recent headache. My hardware consists of a Motorola MB8600 DOCS 3.1 modem w/...
rax120_rax80
Mar 12, 2020Apprentice
Good question. When I said the problem occurs again after a factory reset, the DNS failure that is the root of the issue occurs again. Although, the caveat is I re-apply my configuration from a backup. I haven't left the RAX120 in the default factory configuration, because I have a bunch of clients and it would take e an hour to manually setup the MAC filter again. I can give a factory reset a go and leave the settings default to see if it is any better.
The one thing that stands out to me is that no settings changed for a month before the random DNS failures. Now it's all the time. I would allude it isn't the non-default settings unless there is a time bomb in a particuar setting.
Newfiedrool
Mar 12, 2020Virtuoso
Try it without the saved config, using one can bring back issues which let's hope may have been your issue in this case or a shortcut elsewhere maybe.
I've not experienced your issue and I'm also running a similar setup but would probably say the RAX80 might not be the best product for your needs even if it's a freebie and not in use.
Try it without any saved config and with just basic devices connected and slowly add devices at length maybe to see if an issue rears it's head.
