rax120_rax80
Mar 09, 2020Apprentice
RAX120 Router Random Disconnects
Hey everyone, I know that I'm not the only one with problems on the Nighthawk WiFi 6 devices, but thought I'd post my most recent headache. My hardware consists of a Motorola MB8600 DOCS 3.1 modem w/...
Topology
Mar 20, 2020Virtuoso
FYI: Readers of this thread may be interested in OpenDNS Prosumer, a product that uses an IPsec tunnel to encrypt DNS traffic for privacy, and blocks malware domains for security. I have used it since installing a RAX120 a few months ago, and have not observed any DNS problems to-date.
kschroed
Mar 20, 2020Star
Yeah OpenDNS is nice but it doesn't help with this problem at all since the problem is in the Router Proxying DNS request. If you happen to be manually setting DNS on your downstream devices you could bypass the issue or if your using DHCP server not on the Netgear you may also bypass this particular problem and configure DNS resolver on your endpoints that is something other than the Router address.... If you don't use the router as your DNS resolver this particular issues would not affect you.
