rax120_rax80
Mar 08, 2020Apprentice
RAX120 Router Random Disconnects
Hey everyone, I know that I'm not the only one with problems on the Nighthawk WiFi 6 devices, but thought I'd post my most recent headache. My hardware consists of a Motorola MB8600 DOCS 3.1 modem w/...
dcinca
Mar 27, 2020Apprentice
I had this problem. but now it's working good. Here are what I did:
1.Upgrade to .118, reset and then setup router
2.Unplug any thing from USB ports (Critical bug for 2.4G, maybe design fault)
3.Don't use HT160 for 5G (Critical bug for 5G)
4.Enable AX,(lower the ping for 1-3ms)
by the way, 30-30-30 is not working for Rax120, the router won't boot up When I did 30-30-30, That scared me. I thought it's bricked. When I tried to press the reset buttom for 7 sec again, then the router is back without losing any configuration... that's weird.
- NewfiedroolMar 28, 2020Virtuoso
dcinca wrote:I had this problem. but now it's working good. Here are what I did:
30.30.30 is no longer needed on modern routers, if anything you will corrupt the memory.
