rax120_rax80
Mar 08, 2020Apprentice
RAX120 Router Random Disconnects
Hey everyone, I know that I'm not the only one with problems on the Nighthawk WiFi 6 devices, but thought I'd post my most recent headache. My hardware consists of a Motorola MB8600 DOCS 3.1 modem w/...
bamcgregor89
Mar 30, 2020Aspirant
I wanted to throw out that my RAX120 has started having issues proxying DNS as well. Started last night when it stopped sending traffic to my Pi-Hole for resolution. Nslookup queries to router would return no response, while queries directly to the Pi-Hole would return expected results. Reboots get it going again for a bit, but it eventually drops out after a while.
Router DNS was changed to public servers (Quad 9, Cloudflare, and Google) and was updated to latest public firmware (v1.0.1.118) with no improvements - DNS resolution stopped sometime this morning again.
I currently have a workaround (Pi-Hole is now running DHCP for my network so devices can pick up functioning DNS settings automatically), so I'm not looking for a fix, but I want to make it known to Netgear that this is indeed an issue. FFS, if I wasn't tech savvy I'd be dead in the water having to reboot the router every few hours.
If nothing else, allow users to bypass the stupid DNS proxy and push the actual DNS servers to devices over DHCP. At least the option would allow everyone here to get back to working order.
- a3gillMar 30, 2020Aspirant
Same issue on and off for me, too.
To be clear, the problem is that DNS Relay is failing, right? I can manually assign ISP DNS to clients and all is well (or, as mentioned, configure an alternate DHCP Server/DNS Relay Server).
My experience...:
- First noticed it with 1.0.1.114.
- Applied 1.0.1.118 hotfix and neither better nor worse.
- Rolled back to 1.0.1.108 and all was well.
- Applied public release of 1.0.1.118 and no issues for days, perhaps weeks.
- Configured and applied an Upstream QOS policy and rebooted. Now, this evening, I've lost DNS resolution via RAX120 DHCP twice.
- Currently: I removed the QOS and it ran fine for a few hours, no issues and just now re-applied the QOS.
So far so good. We'll see. If it craps out again I have my config backup and FW 1.0.1.108 ready to go if need be. Fingers-crossed :)
Thanks!
