rax120_rax80
Mar 08, 2020Apprentice
RAX120 Router Random Disconnects
Hey everyone, I know that I'm not the only one with problems on the Nighthawk WiFi 6 devices, but thought I'd post my most recent headache. My hardware consists of a Motorola MB8600 DOCS 3.1 modem w/...
dj2819
Apr 20, 2020Apprentice
Honestly I think the latest routers from Netgear have really buggy firmware. I been only using Netgear routers since the 54g days and the last Netgear router that actually worked flawlessly was the R8000. I upgraded that to the R8500 and out of nowhere it started to do this thing where it would disconnect all clients from the wifi randomly 1-2x a day. Being frustrated with that I upgraded to the RAX120. I really hope this weird DNS issue isn't that bad (I only had it for about a week and only experienced that issue once).
TerryPh
Apr 20, 2020Virtuoso
Agree with R8000.
With this new RAX120, I have been using the router for a year or so with expected minimal disconnection/reconnection .
I am keeping the setting as simple as possible with the new updated fw .118
It seems to work ok, with few random disconnection.
dj2819 wrote:Honestly I think the latest routers from Netgear have really buggy firmware. I been only using Netgear routers since the 54g days and the last Netgear router that actually worked flawlessly was the R8000. I upgraded that to the R8500 and out of nowhere it started to do this thing where it would disconnect all clients from the wifi randomly 1-2x a day. Being frustrated with that I upgraded to the RAX120. I really hope this weird DNS issue isn't that bad (I only had it for about a week and only experienced that issue once).
- dj2819Apr 20, 2020Apprentice
TerryPh wrote:I am keeping the setting as simple as possible with the new updated fw .118
TerryPh What do you mean by "as simple as possible". I haven't enabled anything fancy in the settings. Just using it as a router, the only settings that I care about is MU_MIMO enabled. I have QoS off and guest 2.4 enabled. Everything else is default I believe. I don't use any storage drives or any of the other extra features.
- dj2819Apr 23, 2020Apprentice
I noticed a new issue. One of my HomePods randomly drops connection from router. Either I have to power cycle the Homepod or reboot the router. It isn't a DNS issue as it is not even connected to it (doesn't show up in the admin page nor a network scan tool). Rebooting the router holds connection for about 2 days before symptoms show again.
Any suggestions? I still need to do the factory reset and never log in again method that some of you have mentioned previously.
