mwyoussef
Dec 30, 2023Aspirant
RAX120 setup problem
Hey everyone! My WiFi extender (used as an access point) died. I have an RAX120 and after resetting it and trying to set it up as an access point, it has been nothing but a headache. I know I’m not ...
Dec 30, 2023Guru - Experienced User
- mwyoussefDec 30, 2023AspirantI did that and my router management page just crashes and I go back to the first step…and I have to reset the router AGAIN and start from scratch
- FURRYe38Dec 30, 2023Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- KitsapJan 03, 2024Master
With the power to your RAX120 turned off, make sure you Ethernet cable connects from an active output port on your ISP gateway to the WAN input port on your RAX120. Restart your RAX120.
Log in to the management page on your ISP gateway to determine what IP address has been assigned to your RAX120. You would use this IP address to log in to the RAX120 user configuration page.
